Trackpad modifers for zoom/orbit on Mac does not work
after the 2027 update, my old routines for trackpad gestures on a MacBook Air has changed.
I cannot get it to work.
Command + alt + gesture does nothing.
I guess there must be some mapping for the keys that does some overriding, but I cannot figure out that I did any of that.. :slight_smile:
nothings seems to be out of the ordinary..
Your list doesn’t show command alt. Is it possible that you mean control command?
The old way of orbiting or panning by holding control and command, and dragging, is still in 2027. Only difference is that now you don’t have to drag. Try holding those two keys, then stroke the trackpad instead of pressing on it. The orbiting should work. You can press and release shift to go in and out of pan.
ah- just stroking the trackpad works. Thanks.
But nevertheless I find that the old way does not work for me (control-command -click-drag)
That gesture will be interfered by the middle-button menu appearing in stead. That didnt happen before.
The interference happens when you do the click onto the trackpad:
So: control-command so far so good
moving a finger along the trackpad works, its orbiting.
But: a click, or just a light touch not moving, will invoke the middle button menu.
I’m trying to cope with the change from click and drag+modifier keys to just slide, too. The huge disadvantage is that you have to lift the fingers off the keys every time you reach the end of the trackpad before your orbit/pan is finished. I totally had given up to use mouse and 3D mouse since I had built those movements into my movement memory years ago. Now I’m being slowed down enormously by a useless additional movement each and every second. Why would anyone prefer that?
There seems to exist no method to customize the behavior of V 2027 as far as any information goes from AI assistant or other sources. Has anyone out there further information on this?
Right, so don’t do that. Only stroke the trackpad.
well I as well find the new method more cumbersome and slow to work with. There´s one less motion, as you dont do the click-drag, but as you say, you have to lift the fingers of the keys every time, (to set a new origin for orbit) so that makes the whole gesture a bit clumsy and more prone to error.
the release notes states this:
Both Windows and MacOS versions received improvements to existing touchpad support through the use of additional modifiers.
MacOS devices have had touchpad support in SketchUp for a while. SketchUp 2027 extends this same functionality to Windows while providing additional improvements to both platforms.
To me this reads that the idea was to keep the old gestures, and add some new ones. I would suggest that Sketchup reinstates the old gestures ( and keep the new ones, I guess).
Also, gestures are gone in Layout. With the new speed of Layout in the latest releases I could pan frantically around the drawing while dimensioning. Now its back to zooming out, and then zooming in some other place… so that’s a setback.
Sure, I practiced this during the past days and more or less just that. Now that the decision how this works was made one will get used to it, I guess. Too many movements of the left hand are necessary for my taste, though.
I’m also struggling with the unified UI. Also here so many shortcuts I had built through many versions don’t work any more (e.g. toggle large toolset, why that?). At least one of my greatest wishes is there: A shortcut for resetting the axes to world origin.
Other improvements like the whole procedural stuff are great. Just scratching the surface at the time.
…plus different from in SketchUp panning works with click+stroke. Not consistent, that’s a real flaw.
I have filed a case for this to be a bug, as the release notes clearly states that the new behaviour is “additional modifiers”, when that is not the case for SU, and certainly not for Layout, which now has no trackpad panning that I can see. I have tried just about any thinkable key combination to see if there would be any undocumented gesture.
Just zooming in and out to navigate the page makes you look like you dont know the software you’re using :slight_smile:
Assuming we are stuck with this new behaviour (which is less ergonomic for us Mac users than the previous method) - I have found that keeping my fingers “resting” on the the modifiers and pressing and releasing it is possible to retrain the muscle memory. Still, it feels like a pointless change and has caused a lot of frustration and breaks in my thought process and work. As navigation around a model is fundamental to working with Sketchup I wonder if any Mac users were consulted about this change?
