Thats extremely kind of you, maxB. You have gone above and beyond. As you can see, this is one of my prototype designs as I figure out how to build beautiful elbows with internal wiring cavities for the motors Iāll be using. At the moment, I cannot open your sketchup file because I only have Sketchup 2015:
But I have continued to work using a clean method which allows me to make constant changes without breaking anything - to group every part of a shape and not combine them at all until the end.
My elbow consists of two motors - tilt and pan.
Now the shaft of each motor is only 5mm wide, so it is flimsy and weak in the extreme without a support lip/rail.
The design you made without errors is part of an idea I had that I may still use, to screw lips around edges to lock the tilt segment to the pan segment. But since that idea, I have been redrawing a cleaner design. I have a lot of prototype prints in front of me with the motors and electric ruler in front of me when Iām drawing.
At the moment I am trying to create a tilt/pan combo dome cylinder without any visible seam at all - the rotation will be concealed underneath at the base of it all. This will lessen the lines on the robot arm, so I am refining the design to make all connections including the lips internal.
I need a minimum thickness of 3mm of PLA or ABS plastic for strength for all parts of the structure. Unfortunately, due to the fact that artificial shafting by way of using cogs required more strength than anything I could print could bear, I had to consider not using cogs for prototyping cheaply with my printer. Cogs need to be made out of metal to tolerate the torque, otherwise the teeth snap off. This design in this thread eliminates the need for any artificial shafts, because I have pushed the servos all the way to the edges of cylinders so the shafts are now centred. However, this is supposed to be a womanās arm with an elbow diameter of 62mm. This is too narrow for the required motors.
As it stands, the cylinder is already 70mm diameter. Nevertheless, I need the cylinder to be wider so that it can encompass the pan segment inside it. While remaining uniformly 3mm thick, I want to resize the cylinder part of this drawing to be 76mm diameter, and more importantly, I need to know how to do it. I can see thereās a scaling tool, but Iām not sure how to get the result I want.
Please remember that I have been working on this project for over a year (mostly braking systems and electical components) so I already have around 100 elbow designs. That equals around 10,000 if you count the ones I scribbled out along the way. So when I ask for 76mm, I might mean 72mm later, or even discard the idea of 3D printing anything at all because in the end this will be made of much thinner aluminium. My priority at the moment is to make an elbow from the printer that is as streamlined, sturdy and user friendly as possible. My own elbow is 82mm wide, so a 76mm wide elbow is not unusable. It seems a womanās arm demands that I return to the far narrower artificial shaft designs.
But for now, can someone please tell me how to resize a shape based on diametre in millimetres?
I am attaching the work done so far in my redesign in case anyone has any ideas that could streamline this prototype better using 100% 3D printable components. If you have any ideas, please ensure you leave hollows for the wiring. The motors are 38x19.5x40.5mm.
70mm.skp (1.3 MB)
