Tile Crafter - Looking for Testers & Feedback
Hello everyone! I’m happy to share Tile Crafter, a plugin I have been working on. There are already many tile-making plugins available, but this one offers a few additional features, including a wider range of tile options and settings, as well as tools for creating stones, slats, and terrain.
I would be grateful if you could test it and share your experience. Any bugs you find or suggestions you offer will help make the plugin better for everyone. Thank you very much for your time and support.
tile_crafter-1.0.11-build154.rbz (383.2 KB)
tile_crafter-1.0.2-build110.rbz (206.1 KB)
It also supports multiple selected faces, which may not be available in some other tile-making plugins.
Added Column Offset Y so the planks can be staggered in the other direction too.
tile_crafter-1.0.2-build110.rbz (82.0 KB)
Hi Hamzah,
I discover your new extension but with my 2017 SketchUp I always have this traceback
Error: #<SyntaxError: c:/users/patrick/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/tile_crafter/main.rbe:803: syntax error, unexpected keyword_rescue, expecting keyword_end
rescue => e
c:/users/patrick/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/tile_crafter/main.rbe:817: syntax error, unexpected keyword_rescue, expecting keyword_end
rescue StandardError
C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in require’
C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in load' C:/Users/Patrick/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tile_crafter.rb:27:in register_extension’
C:/Users/Patrick/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tile_crafter.rb:27:in <module:TileCrafter>' C:/Users/Patrick/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tile_crafter.rb:8:in module:HZ’
C:/Users/Patrick/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tile_crafter.rb:7:in `<top (required)>’
Could you make a light modification for this version please? SketchUp v2017 is the last free application so very important.
So far on 2026 it’s working pretty good. Thanks for sharing.
@Spirou4D Try this version and let me know if it works.
New updates:
  • Stones are now more rounded instead of triangular.
  • Added roof tiles.
  • Added road curbs.
It may still be rough in a few places. If you spot any issues, please let me know so I can fix them.
Ok I go… Thks.
" No panels placed — try a larger face, or smaller member width / spacing."
I have always this red little message bellow after generation ???
But all is ok it work very well ! no problem.
Congratulations Hamsah !
Try this one. Next time I will download the 2017 version.
tile_crafter-1.0.11-build155.rbz (383.2 KB)
Ok I go…
Ok This time all is perfect ! Top-notch!
Just green message et disappear.
Seeing my plugin featured on YouTube was a really special moment. I truly appreciate your support. Thank you so much for testing it and helping share it with others. It means a lot.
@Murat75
