We’d like to share screwit3D, a SketchUp extension for threads, bolts and holes. Click a face, and it drills the hole through every wall in the path and places the real bolt, washers and nut, with a length from the stock range. Or it cuts a real thread straight into the part, ready for 3D printing.
Threads
Real modelled threads cut straight into a part, through or blind. Light geometry, so the model stays fast.
Thread on any shape you draw (new in 1.1, beta): click the circle of a neck and of a lid, and you get a matching pair of printable threads. The lid lines up when you tighten it.
Clearance for 3D printing, for metric and inch threads too. A test plate with several clearances shows what fits your printer.
SI3DP, our own thread standard for FDM printing: 45° flanks (no supports), pitch = 0.3 × D, clearance built into the standard (bolt −0.10 mm, hole +0.15 mm), checked on real prints. Sizes S6 to S20, printed bolts and nuts too.
Bolts and holes
ISO / DIN metric and ASME inch (UNC / UNF) bolts, nuts and washers, with all common heads.
Plate + plate, tube + plate, tube + tube: it measures the parts and drills every wall. Nuts hidden inside a tube get an access hole for the wrench.
Bolt length from the stock range, or cut to length: it tells you which bolt to buy and how much to cut off.
Every joint stays editable, and holes go into the component, so every copy gets them. Bill of materials with DIN / ISO / ASME names.
Fill in between: select two joints, and it spreads more of them evenly between the two. Change the count or spacing later, with a preview right in the model.
Screw in: press and watch the bolt go into the thread or through the holes, right in your model.
Select all identical joints with one click and change them all at once. Holes without a bolt can be moved and resized too.
Also in 1.1 (beta): STL and DXF export with the parts laid out for your print bed or CNC sheet, and shape tools for rounded and chamfered edges (full version).
Details
SketchUp 2019–2026 desktop, Windows and macOS. The free version has all joining features (up to 3 of each kind per model; purchased hardware in M4 / M12, #8 / ½", S6 / S12) and 3 trial pairs of thread on a shape. Full version €39 excl. VAT, one-time, all 1.x updates, 3 computers. https://screwit3d.com · what’s new in 1.1: Features — screwit3D for SketchUp
Questions, ideas and bug reports are very welcome. We’ll post updates in this thread.
Drill and insert: a bolt can’t go right at the edge of a part, because it wouldn’t hold there. screwit3D follows the technical rules for bolted joints, like the minimum distance from the edge, so every joint it makes really works. In your screenshot the cursor is on the narrow side of the plate, right at the corner (0.28 mm from the edge), so it won’t place a bolt there. That’s what the red message next to the cursor is telling you: it always shows why a bolt can’t go to a spot.
About our video: the cut you see there is just a section view. We placed a section plane through the groups so you can see the bolt inside, but the parts themselves are not cut. The bolt is actually on the top face of the plywood, about 15 mm in from the edge, going down through both parts. Click on the top face like that and it will drill and insert. The plates should be groups or components.
The Insert part error is new to us. screwit3D runs on SketchUp 2026 without it, so it looks like something specific to your setup. To track it down fast, could you email the diagnostic log (menu Extensions → screwit3D → “Open diagnostic log”) to info@screwit3d.com, together with your exact SketchUp version (Help → About)?
@Jojo9 quick update: we found the cause. Another extension installed in your SketchUp changes one of Ruby’s basic functions, and screwit3D tripped over it. Version 1.1.28 is out and no longer depends on it.
To update: open the screwit3D panel and click the new-version bar at the top, or download it from https://screwit3d.com
Then please try Insert part again. If anything still looks off, send us the diagnostic log (Extensions → screwit3D → “Open diagnostic log”, or %APPDATA%\screwit3D\vrtak_live.log) to info@screwit3d.com. In 1.1.28 the log also shows which extension it is, so we can make sure screwit3D works well alongside it.
@Jojo9 great to hear it works now, thanks for testing!
Positioning from a corner: draw two guide lines with the Tape Measure tool, for example 20 mm in from each edge, and click where they cross. The hole snaps to guide lines, so it lands exactly there. You can also adjust a finished bolt later: click it with the Drill tool, choose Move, and nudge it with the arrows using a set step, or click a new spot.
Several bolts at the same distance: place the first and the last bolt, select both, and choose Fill in between in the edit window. Set the count or the spacing, check the preview in the model, and apply. It drills all the holes too.
@RLGL thanks! Move/Copy works for the bolt itself, but it doesn’t cut the holes in the parts, so Fill in between is the quicker way here.
Wood screws in metric (DIN · EN) and inch (ASME · ASTM) standards: universal DIN 7505, classic DIN 7997, washer head, lag screw DIN 571 and confirmat, plus inch wood screws (ASME B18.6.1), deck, lag (ASME B18.2.1) and drywall screws (ASTM C1002). Pilot holes are sized for softwood, hardwood or chipboard, confirmats get the stepped hole of a confirmat drill bit.
It shows you how to fix it
When it can’t drill, the panel explains what to do, step by step, with a short animation. Left: too close to the edge, so move away and click. Right: two copies of the same component, so answer Yes to make one unique, and the hole ends up only where you want it.
Components, handled
Holes still go into the component definition, so every copy gets them. When a copy elsewhere in the model would end up with a hole but no bolt, screwit3D makes just that copy unique, automatically. In less clear cases it asks first. Works with copies of whole assemblies too.
Screwed in, or unscrewed
Every joint can be shown screwed in or unscrewed, and you can set it per scene. Switch scenes and the bolt screws in or out with a smooth animation. Unscrewed is great for assembly drawings in LayOut: the bolt sits next to its hole, so it’s clear what goes where. Switch it back any time, the holes stay.
The whole add-on is translated: the panel, the messages at the cursor, the step-by-step help, the edit window, menus, settings and the licence screens.
It follows SketchUp’s language automatically. You can switch it any time in Settings → Language.
Part names in the model and in the parts list follow the language too: Schraube M8×55 DIN 933, Tornillo M8×55 DIN 933.
Standards and designations stay as they are: DIN, ISO, ASME.
Hex key fits printed bolts. A printed wall swells slightly inwards, so the hex socket of every printed bolt is now 0.4 mm wider across flats (S8: key 6, socket 6.4). Labels still show the nominal key size, steel bolts are unchanged. In an older model, insert one bolt of the same kind and all identical bolts are rebuilt.
Component copies. A copy gets a bolt only where it joins the same components as the spot you clicked. If the copy has a different component there, it is made unique and stays without a hole. Also fixed: a copied pair of identical components no longer gets two bolts in the same place.
Update from the panel ( → Check for updates) or download it at screwit3d.com.
If you use SketchUp in German or Spanish and something sounds off, let us know. Native speakers’ feedback is very welcome.
A big one: a whole new look, and new tools that came straight from your messages. Thank you, keep them coming.
A new look
The whole extension has a new design: the panel, the edit window, Settings and Print & export. Clearer steps, bigger previews and smooth animations as you switch options. Prefer it calm? Animations can be turned off in Settings.
A bolt into a hole the part already has
New snap option Into hole at the bottom of the panel. Point at a hole that’s already in the part (drilled by you or imported) and the bolt snaps in:
round holes go to the centre,
slots and hex holes go onto the axis, and a guide across the slot sets the exact spot,
the part with the hole is not drilled again, only what lies under it.
It works on faces split by lines and on imported parts too.
Small bolt, large hole
If the head or washer would fall through the hole, screwit3D adds a large washer DIN 9021 by itself and lists it in the bill of materials.
Threads only where you need them
New setting in Settings: threads on fasteners Everywhere · 3D print only · Nowhere. Bought bolts and nuts can stay smooth, so the model is much lighter. Switching rebuilds the fasteners already in the model, and one Undo takes it back.
Also new
SketchUp stays fast: the tools no longer redraw the model all the time, only when the mouse moves.
Three parts in a row and the joint type takes two? A window asks “How many parts to join?” instead of skipping one silently.
Add another board to a finished joint from the edit window.
Rivet nuts: the hole for the collar gets a clearance.
Countersunk heads go through a thin tube wall too.
Shape tools: type the rounding radius, and radius 0 removes a rounding.
Fixed: SketchUp could freeze in “More segments” and when deleting many joints at once.
screwit3D now speaks Portuguese too (Brazil), next to English, Czech, German and Spanish.
Free for everyone who has screwit3D. Update from the panel (the new-version bar at the top) or download it at https://screwit3d.com
As always, questions, ideas and bug reports are very welcome.
