I don’t want to update the other programs I use integrated with Sketchup because they are version 2023. Can you send me the file?
I still can’t open the file
just install 2025. you don’t have to uninstall 23, it won’t change it, you can have both installed.
ı’m sorry.
I don’t understand, is my file not opening because of the version? Will I be able to open it when I install the new version?
Yes. That’s what I told you. I also showed you that it will open in SketchUp 2025.
hi everyone
i face the same problem
can someone help to recover my file?
thanks before
lots of things to purge. as usual.
it opens in sketchup 25, you should update (just install it and login, it’s part of your subscription).
it shows an error message on launch, didn’t pass the integrity check. but still opens.
another good reason to switch to 25 is that it will ask you, upon saving, to purge. and you really need to purge, this file is filled with stuff from the warehouse.
thanks brother, it works ![]()
Hi everyone, I’m facing the same error. Can anybody help fix my file? Here’s the link to my file
Thank you
