I have a problem with getting a thicker part on my bracelet i am designing.
If you have a look at the photo i attached, you see that there is lock at the back, but in the front i need a thicker part.
I tried a lot, searched the internet but i can’t manage to get a thick part blended in the bracelet.
You’ll need to connect the ends of the arc to create a face.
Why don’t you try my first option. Your model isn’t that complex so it wouldn’t be that difficult to start over. In fact it would probably save you time.
first select the object you want to cut out, then the object what needs to be cut. So first the tube and then the bracelet. Then click on substract or trim.
