Temporary Dimension in Tool
#21
For now I’ll go with: rgb #447088
https://www.color-hex.com/color/447088
It’s kind of a muted green-blue. Eventually I will make the color configurable for the user.
#22
Throwing a bit of a “spanner in the works” - you may also want to consider the directionality of your temporary measurements, in which case, you may want to make them turn the colour of the axis when aligned.
#23
The wall wire frame already does turn the color of the axis when aligned, however the dimension does not. I think this will work.
#24
If you want text and other info to be visible regardless of background color, also for colorblind people, I’d recommend to draw a background rectangle behind it with a contrasting luminosity. I do this in Eneroth Tool Memory and ThomThom does it in SUbD.
