Template Update question
After updating to 2016 I have successfully loaded my personalized template but it appears to be styles and dimensions only.
Is there a way to reproduce your tool bar orientations, loaded ruby scripts, personalized menu and layouts, etc. or does that customization have to be reset at each update? That’s a real pain with Ruby’s…
Those are not template settings. You can mass install extensions via the Sketchucation PluginStore and Extension Warehouse although it might be a good time to consider doing some housekeeping and eliminating extensions you don’t need.
Toolbars will need to be positioned manually. I make a screen shot of the pervious version and import it into the current version so I can see where to put the tools without having to go back and forth.
Other things like custom style and material libraries can be imported from the older version.
