I am working with a steel fabricator who has started using Tekla BIM software. Tekla is a company within the Trimble family and is full 3D. Does anyone know if there is a way to import TBP files into SU?
At present, the fabricators export to DWG and I import from that. But one of the problems is that the DWGs have a single layer so even the text boxes look like linework. In any case, it seems daft to go from 3D to 2D and then back to 3D if you can avoid it.
You don’t want to cope with an imported Tekla ifc file in Sketchup.
The way it is importing simular geometry components as unique definitions is bloating the component browser, where instead, they could be instances of the same beams.
That is, sort of, what happens when importing IFC to any application. Despite this, I have used imported Tekla structures without problems in Archicad. In SketchUp you always have the option of exploding the import to get rid of excess components.
