Tape Measure do not create parallel infinite guide lines from “guide+guide point”
I want to report an issue, which may be intentional or not - anyway, i think it’s wrong.!
When you create a “guide+guide point”, there is no way after that that the Tape Measure can reference to it and create infinite parallel guide lines.
But, when you do the same thing with other extensions (Fredo Draw Along, Dezmo Pro Line), then the Tape Measure can reference to it and create infinite parallel guide lines.
Testes in SU23 and 26.
Edit: In fact, afterwards, SketchUp engine doesn’t recognise that as an internal object - no other tool inside SketchUp can reference to it…!
Guide points are guide points, not guide lines, so the Tail of a guide point is just there to show you where it is.
Allright.!
Thanks for the answer.!
