Tall Walls Error
Hi. I imported a file from autocad and now when I am trying to push/pull a wall of 6metres, the walls is coming out as ridiculously tall.
. I am using the same units as my autocad file. HELP please
How about uploading the .skp file so we can see what you are working with?
Operator error with the CAD user, I’d bet.
museum sketchup.skp (1.9 MB)
When you import the cad file make sure you set the units correctly in the import options.
Keep in mind that setting the units in Model Info->Units or changing the template does not affect the import options.
In case you missed the options button.
Import options
Thank Y’all for the help. solved it!!!
