Tags - show count of tagged objects in docker
This will help to eliminate empty tags, and do quick “sanity checks”.
With the plugin cleanup from ThomThom you can get rid of tags that aren’t assigned to any object.
Well, you can also “Purge” from the Tags palette. Not sure it that’s quite what you want though.
@eneroth3 also has an extension that reports what uses a layer or tag, but I don’t have it installed at the moment.
yep, that one :
https://extensions.sketchup.com/extension/14be4cfe-b2a5-41b2-a739-a0042e422f2e/eneroth-layer-usage-inspector
and +1 for the Purge. no need to use cleanup for that.
True, purging will also delete unused stuff, I’m just so used to cleanup and I have a shortcut assigned, I think there’s no way to create a shortcut for native purging.
I know it’s not the same, but the iPad has a preference that can be set to purge unused at every save.
