Exporting to DWG has its limitations in Sketchup. Exporting a 3D model with tag information maintained in layers is possible. Exporting a 2D section loses all tag information. The section slice exports to SectionCutEdges and all visible objects in the model behind the Section plane get transferred to layer 0.
Creating a scene from a section, then sending it to layout and then exporting it to DWG shows the tags as layers from the object behind the section plane. But not the tag information of the section slice. Why is it impossible to share information of the section slice?
Please add the tag information from the section in future export.
It is not in the extension warehouse, only on their own web-site. Downloaded it, installed it but then stops with an error. I Don’t seem to be able to comment or review on their web-site either. Are you sure this is a valid product?
Ok, I tried 5D+. It’s a very sophisticated and extensive extension. Very Impressive.
But for the section part, the cutting edges, it does the same as SketchUp does. It creates a layer named SectioCutLines as well as one for the hatches. I would like to see the name of the tag though what the section is taken.
If you cut through an object on the tag Wall I expect to see in the export file a layer with the name Wall where the section is taken. Or maybe even a Wall-Cutline will do. Now I’m oblivious of what the SectioCutLines line represents.
Thank you for using it.
Your request will match with using Curic Section to generate custom haches for section cuts.
Then using 5D+ to export DWG/DXF, it can help you generate section cut lines with layers exactly as your requests.
hello, my little robot made an export plugin for me, because native dwg/dxf export is ridiculous, bugged and useless - I created at least one topic about it. (I bought curic2cad a while ago, but it crashes too often)
I’ve only been on it since yesterday but it is already promising. If you’d like I can post it here.
It converts components to blocks when possible, you can add white plain hatches to them (optional yet very useful), entities are automatically hidden when section cuts go through closed items, there’s an option to “see through” translucent materials, an option to draw the outlines of smoothed objects.
all tags are kept and section lines are tag-dependent.
It has two engines, one in ruby which is very slow (just like native one) and an accelerated one in C++. From my tests, C++ takes 60s for 1000000 faces - 800000 lines when ruby needs more than 800s
and oh - it has a progress bar, revolutionary !
I tested it on windows, but not mac. I’ll be able to attach it here sometime later today
