Hello every body,
I am new on this community and pleased to join you.
I have an issue with balises (layers) on skp 2020. I name them with number so the 1-XXX should always be before the 2-XXX etc. But with skp 2020, when I hide one, it move to the end of the layer’s window. I always use the same layers and I like them to stay in the order i chose, hidden or unhidden.
Is it a way to keep them in orden, even with hidden layers ?
Thank’s a lot.
@Chavanes, you can sort tags by unhidden/hidden or by name. Click on the appropriate tab above the list to change which one you would like.
I’d like to suggest you edit your topic title to read:
“Order of tags display in Tags panel”
Based only on your current title (“Layers order in skp 2020”), and before reading your question, I thought two things:
- You aren’t really on 2020, since 2020 replaced “Layers” with “Tags” and
- You were asking about how Archicad style Layers are overlayed in Sketchup (they aren’t - and that’s part of the reason Trimble changed “Layers” to "Tags!)
Changing the topic title will help people searching for answers to your same issue in the future.
