hoe doe ik dat met windows 11 pro 21H2 aan mijn wacom intuos pro
How do you do what?
@m.lensink1 , you need to explain what “ends” you have got and what exactly you want to connect. Where does SketchUp come into play? Otherwise you only get people guessing and with best of luck having some attempt in answering.
@m.lensink1, je moet uitleggen welke “einden” je hebt en wat je precies wilt verbinden. Waar komt SketchUp om de hoek kijken? Anders laat je mensen alleen maar gissen en met veel geluk een poging doen om te antwoorden.
As a general note, you would probably have to go to the Wacom website and download and install the Windows 11 driver for your device, if it exists.
Some people prefer to use a tablet instead of a mouse with SketchUp, but it doesn’t provide any special support for them.
ik heb windows 11 op mijn pc
het gaat mij er om hoe ik via de eigenschappen van mijn wacom tablet sketchup kan koppelen metelkaar
Your Wacom tablet can be used to move the cursor just as a mouse would in SketchUp. Since SketchUp is not a drawing program, a lot of what your tablet offers (pressure sensitivity, gestures, etc) will not be of much use, but you can use it to draw anythign you woudl if you were using a mouse.
i have found the program on my pc and folders
thanks
