I’ve been trying to create a foldable side table. However don’t seem to be aligned no matter what I try.
Any guidance is wellcome.
Thanks
Folding Slatted Coffee Table.skp (218.1 KB)
Thanks
It can be somewhat corrected, but it’s easier if you redraw it from scratch correctly. Draw only half and then mirror it.
You can start with the basics of SketchUp at YouTube - Square One
What is your goal for the model? Is it just to have something to show in setting with chairs and other furniture or are you trying to make a woodworking plan so you can build the table?
I’m trying to have plan for the DIY build woodworking table
Are you modeling the parts in place as you create them? Or are you modeling them and then trying to assemble the table? Generally I find it easiest to, as much as possible, model the objects in place where they will “live”
There seem to be a number of cases in which you haven’t been moving copies of objects on axis. That’s going to create problems.
Are your dimensions correct? As it is your table is quite small.
This is something that the SO requested to put her coffee mug on, when in the garden. It’s going to be very small, 45cm x 45cm x 45cm
So you may have enough information in your model as it is to build this so she doesn’t have to wait around holding her coffee while you get the model recreated more precisely. If you want I could record a video showing how I would go about modeling it. Are you satisfied with the design of it as you have it?
I’m satisfied with my design, I’ll start building it this weekend. In any case that video will be great.
Thank you
Great! BTW, please update your forum profile. It shows you are using an old desktop version which is evidently not so anymore.
As you can see I made a mistake while attaching the Long Stretcher, I glued it to the wrong side of the leg, although I did a dry fit
Oops! A simple fix, though? Otherwise it looks like you planned your work and worked your plan. Good deal.
