T marks that wont delete
I’m having issues trying to delete two T marks that have appeared while working on a floorplan. can anyone please help??
Maybe we can help if you’d share the model file or at least a screen shot so we can see what you have going on in your model.
Maybe you just have a style with endpoints turned on? If that’s the case, you can edit the style and turn them off or you can select a style that doesn’t have endpoints turned on.
Screenshot%20-%205_14_2019%20%2C%207_04_44%20AM
The reason we need to see the model is that we don’t know what the “T marks” actually are.
I assume they look to you like "T"s, but are not text objects. Can you more precisely describe what they are, or attach a small (cropped) screenshot?
Possibly they are:
  • Line extensions at the end of all edges, extending over the other side of each end point. This is a style feature that may have been activated unintentionally. Open Window → Styles, select the current style in the Styles panel in the tray on the right, go to the Edit tab and the Edge Style section and uncheck “extensions”.
  • Construction point objects (looking more like a fixed-size cross on the screen). These are entities that one can select (best with rectangular selection) and delete.
Could they be little crosses and not Ts at all? If so, it will be a temporary construction point and just like construction lines can be removed by hitting Delete Guides (I have a keyboard shortcut because I use it so often).
Thank you all, I have fixed the problem. They were guide marks!! being new to this program and computer illiterate I had no idea what was going on. Thanks again
