Hello, I just softened all edges of faces hoping that will be able later to fill with one color, but somehow this not work out, any tips?
This looks like a single surface that was created in two mirrored sides, and one side has the back side facing up. You are seeing the backside color on one half. Look at the colors in the upper left of the entity info pallet, or look underneath and the colors will be reversed. Show hidden geometry and select only the grey half, then right click and choose reverse faces.
Upload your model so folks can check it to be sure this is what’s going on.
Thanks, it worked!
Or ‘View Hidden Geometry’ > right click on one little front face > select ‘Orient Faces’ in the context menu that appears
GREAT!
You saved my day!
