I need to change all the surface area colours to one colour (I don’t wont to click on every surface), I thought I do this by highlighting everything?
Does anyone know how I can do this?
If you select all of the surfaces, you can apply a single material to them in one click.
You can also go to the Styles inspector, go to Edit > Face Settings and change the default front color. This color is used on faces with no material assigned. I’d however recommend using different front and back color so you can see if faces are correctly oriented.
