I’ve created a canoe lofting surfaces from section curves (table of offsets) using the curviloft plugin. Is there a way for the surface to retain associativity with the section curves so that if I change a curve, the surface will change to reflect this? I am using 2014 Make.
I am afraid that this won’t work.
You can use subdividers as Artisan or SubD(commercial plugins). These work with raw geometry and when you work it the subdivided surface is automatically updated.
The only way of updating the surfaces with curviloft is to work on the curves then delete the surfaces and create them again.
