lik
1
I am using SDK_Win_x64_18-0-18664.zip. I want to get the default front face color and back face color. The code in vs2017:
int main() {
SUInitialize();
SUModelRef model = SU_INVALID;
SUResult res = SUModelCreateFromFile(&model, "model.skp");
if (res != SU_ERROR_NONE)
return 1;
SURenderingOptionsRef ro;
SUModelGetRenderingOptions(model, &ro);
SUTypedValueRef value;
SUTypedValueCreate(&value);
res = SURenderingOptionsGetValue(ro, "FaceFrontColor", &value);
SUColor color;
SUTypedValueGetColor(value, &color);
SUTypedValueRelease(&value);
when run the row 11 throw exception, as fallow:
I has checked this is not the utf8 coding problem.
I think this maybe the sdk’s bug. Has anybody ever had this question?
Are you checking the return value?
lik
3
I can’t get the return value, it has crashed.
I was referring to row 8, GetRenderingOptions
It may be that you need to call SUSceneGetUseRenderingOptions
Refer to this link: Getting Rendering Options DisplayColorByLayer
lik
5
Thanks for your replies.
I have tried SUSceneGetUseRenderingOptions and SUSceneGetRenderingOptions, it has the same problem.
I pasted in your code, it was failing on SUTypedValueCreate because the passed value was not initially set, so try this…
SUTypedValueRef value = SU_INVALID;
system
Closed
7
