Suforyou Slice / detach cuts the component and generates 2 components well, but often copies edges from one to the other and alters the mesh with the effect of holes in the walls and the cut surface is not generated and will not be plane anymore.
It seems that if a cut is too close to an edge or a point Suforyou draws new edges and ruins the geometry.
image shows how it should be
shows stray edges (60 cm long)
image shows detail before the cut
image shows detail after the cut
After hours of repairing and many more to come I would like to know, if the extension is just not exact enough for this or is there anything I can do to avoid this or is there another tool for this? Thanks a lot for help!
I did several tests. This one I cleaned with meshlab. I need to keep the shape.
The image here is part of the attached file and it shows how suforyou changes the edge of the triangle on the left.
