Hello everyone,
I’m having some scaling issues with my Dynamic Component. It feels like there should be a simple solution to the problem that I am missing.
So here is the issue. I have a DC which is a window, window sill, and an arc on the top of it all.
The arc is a DC that works perfectly when it’s not a subcomponent of the window. Yet as a subcomponent it gets stretched with the parent DC in an inconsistent way.
To clarify, the top right picture is the window and the arc before changing the size:
and top left, is after changing the width of the window. As you can see the arc has been stretched out along its X axis. The X length and the Y length of the arc in its attributes are set to be equal. The arc always stays a 90 degree segment when it is not a subcomponent of the window, but as a subcomponent, it gets skewed.
In comparison (two bottom pics) when working with the Arc DC in separation, the arc scales consistently.
What am I missing?
If anyone can help it would be really appreciated as I have spent hours on this with no luck!
Here is the file:
DynamicWindow.skp (595.4 KB)
