Immediately after starting SU, I choose a tool (Line, Circle, etc.) then click somewhere to start drawing. Nothing happens. I always have to click a second time to start drawing.
This is only after starting up. After using a tool, the behaviour is correct. I get immediate response for any tool.
SU 2020 shows the same behaviour.
SU 2019 is OK. I choose a tool and I can start drawing with the first mouse click.
I have found when I start SU, I need to have the computer focused on the work space prior to selecting a tool. This is also like when I switch focus to the other window or browser I have open to do something else then back in SU I must click again to tell the computer I want to work on my project again.
1 - Start SU. SU starts with the Select Tool active. The cursor is an arrow.
2 - Open the IW.
3 - Choose the Line Tool.
4 - Bring the cursor in the drawing area. The cursor is still an arrow.
5 - Click once. The cursor change to the Pen (Line Tool) but no line is started.
6 - Click again to start a line.
I closed SU with the IW still open.
I started it again and do the same test with the same result.
I quit then start again then close the IW and repeat the test. Same results.
What is bugging me is that the cursor doesn’t change when I select a tool. With SU 2019, as soon as I select a tool, the cursor changes immediately to the appropriate icon. Of course, as soon as I bring the cursor in the drawing area, I can start drawing with the first click.
SU 2020 and 2021 broke something, unless there is a plugin that messes things up.
