Style (used in several Scenes) is being deleted on “Purge Unused” at Save.
(Using Version 25.0.634 64-bit)
Attach a model the shows the issue.
Without inspecting your model, i have tried to replicate the issue.
I only lost the new style when i did not update/save it to the selected scene.
Once updated, it kept the new style during the purge at save.
So i was thinking maybe you did change the style for a scene, but did not update/save it to that scene?
But since multiple scenes use the style, this can not be the issue? … hmm
As @AnnoNiem points out, if you haven’t updated the scene(s) with the style it would get purged. Also if you’ve modified the style but not updated it you would lose the changes. Another possible way this might occur is if you have chosen to not save the style as a scene property.
Thanks - yes, and now I’m feeling stupid!
My “typical” setup has all the Properties to Save boxes checked in the Scenes window - somehow that had gotten changed to ONLY saving Camera and Axes Locations, so wasn’t tying the Style to the Scene - which meant it was “unused” and getting purged at Save…
That’s unfortunate but at least you’ve tracked down the problem and it can be quickly fixed.
Have a brat for me.
Will do - on a Sheboygan Hard Roll - which is the BEST way…!
Thanks
Absolutely!
It’s been a long time since I’ve been to Sheboygan. Too long.
