Strange looking nodes
Hi all,
Recently I’m having some strange issues with the nodes of a model. Everything works fine, just that these are larger and hard to precisely moving things to a refernce, for example. I’m using SU 24 pro. See image attached, is not only when selecting 3D objects but also when using the tape measure.
Any ideas what this could be?
Thanks in advance
There was a problem where text labels would have a black background. That would only happen if you were using the classic graphics engine. It was fixed in SketchUp 2025.
Are you using the classic graphics engine, and not the new one? Is there a reason you can’t use SketchUp 2025?
Hi Colin, I’m going to update now to 2025. The problem with the graphic engine, if I’m not confused with something else, was that when using the pull/puss tool was impossible to see where I was going as soon as the mouse disapeared from the screen.
Hopefully there were other fixes in 2025 that might help.
