I am encountering a strange behavior when I try to draw a construction line parallel to a construction line that is in a subgroup.
It seems the tool does not properly taking into account the transformation of the group.
This seems normal to me. Guidelines are oriented to the world/model axes and guides inside of groups and components are aligned the group or component axes. So editing context controls the inferencing.
But aren’t the angles between guidelines from inside and outside of the group 45, 135, 45, 135? Meaning the guideline inferenced from outside of the nested guideline is 45 or 135 degrees ‘off’?
Hey! It looks like you’re wanting to create guidelines from existing guidelines in the same way that you can create a guideline from an edge. Is that accurate? I believe the current functionality is that guidelines are oriented to the world axis on creation, but I’m seeing something different happening in a test version, so let me look into it. Thanks for posting about it!
