STL plugin issue
Hi
I have successfully installed Stl plugin and after loading an Stl file with no error message, the object doesn’t appear in the UI.
What should I do to fix this ?
Thanks
Julien
Is it too small to see?
Hit shift z and see if it appears.
@Blochjulien - Does this continue to be an issue? Do you have the lastest update? The extension was updated to version 2.1.7 recently.
Hi Box,
I missed your reply and your solution works just fine. The object was way too small. Beginner mistakes.
Thanks for your help :slight_smile:
Julien
Hi Jim,
I did upgrade it but I was just missusing the software.
Thanks for jumping in !
Julien
