If the status bar in 2017 is gone, how do you get it back?
You mean down at the bottom of the SketchUp window? Maybe check to see it isn’t off the bottom of the screen.
Maybe do a cold reboot?
What’s a cold reboot?
Powering the computer completely off and then back on.
Make sure SketchUp is set to Maximized, too.
SketchUp 2017 Make hasn’t changed in more than six years so whatever has happened is due to something on your computer.
You mean filling up the screen?
Tes. Without dropping below the taskbar.
Me did reboot. No dice.
Right click at the very bottom of the screen and select Prompt from the context menu if it is there.
No response on right click.
Screenshot the whole screen.
Running repair- stand by. . .
Failed.
I have exhausted my ideas short of full a re-install.
It looks like your taskbar is hiding the bottom of the window.
Taskbar settings may fix it.
Can you make the SKP window smaller - don’t run it full screen or maximized?
It looks like it is in full screen and your windows task bar / whatever that is down there is hiding the bottom of the SKP window.
I tried that. No dice. It’s not being hidden. It just literally isn’t there.
Have you tried uninstalling and installing again?
Try these steps
it should change to like this:
Grab the top of the window move, then and resize SU window until you really see all the side of the window (Like in animation):
Save Sketchup and Close
Reastart your computer
Other advise, Reset Workspace
Windows 10 taskbar settings - turn autohide on
the taskbar will drop down and disappear.
Is SketchUp underneath it?
