sssfox
January 20, 2015, 3:08pm
62
Thomas,
Here is a copy of the file. There are two different versions of the
piece in the file. The one without the top piece (closest to the bottom)
is the cleanest from a solid standpoint. That’s the one I sent you the
error file from. The object is a rectangular piece with a slot routed
around most of it. I’m trying to add a stepped hole through the part.
One of the ends of the hole ends up in the slot, so I have to make it
into a solid object to subtract the hole from the object. I’m also
trying to curve the end of the slot like it would be with a round
bottomed router bit, but that’s another problem. The only way I can get
this far is to make the faces with the slot using “Follow Me”.
I’m a woodworker and I’m trying to make this part into a solid so I can
add a stepped hole to it. I’m also trying to learn Sketchup and the
best way to do things. I’m not very good at sketchup, but I think I
have most of the basics down.
After all this discussion, I downloaded v2.2.2 and that fixed it. Your
attachment is a Godsend.
Thanks for your help, I’m a happy camper.
Steve Fox
Lynn’s Cradle.skb (1 MB)
zant
January 30, 2015, 12:54pm
63
Hi there,
I am trying to face a quite unexpected problem. I am working with ArchiCad Mesh Tool in order to design a new hights model for my area. As I finished my mesh (separately for present and designed stage) i improted it as a *.3ds file into my Sketchup. Everything was working shiny. All i needed was to click on entity info to get my volume information and compute the difference between both stages. The problem occured when I tried to cut out some smaller pieces of my meshes, to compare it. Afted import the object are not solid. I inspected them with your tool. But I can not really get to this lines. I am very upset, could you guys please give me some hints to solve it… I would be very greatful.
Wow - that’s a big file. I had to download it and open up in an image editor to see it. It’d be easier if you’d posted the screens separately.
Without the model it’s hard to tell exactly, but in the first screens it looks like you’re missing a surface at the bottom of your shape. Then it looks like you fill it, but did you create the fill in a group? Because Solid Inspector reports that you have a nested instance in your selected mesh along with a surface hole.
zant
January 30, 2015, 2:20pm
65
Hi, thx for rapid answer. Sorry for uploading such a snake-pic, but as a new user i was limited to upload just one item
I deleted bottom of my shape, than created a new surface, the problem was that my surface didn’t stick to all of the walls. As you can see on the last screen, when i move this surface, it reveal the gaps between the edges of vertical elements and the fill.
Is there any way to glue it. I worked on a exploaded object.
…well before I posted this I also tried to prove how the ArchiCad settings affects *.3ds file. The mesh with earlier stage works just great. I can’t determine a difference between those meshes. The second one is beased on the first, but at the certain point it loosed its ‘solid’ charcter.
Im not allowed to upload my file, but mayby this works https://drive.google.com/file/d/0B5XpTM6k3ud9N1RYSjlBd2U5TDA/view?usp=sharing
zant
January 30, 2015, 2:54pm
66
Hi,
It seems that it won’t work properly, unless the edge of the mesh consist of limited number of poligons. When I split my mesh into 2 cuboid, I am able to create a solid component, just by exploding and grupping it. Same action executed on a model with complicated edge instead of straight line, results in total defeat. Well, Im hopeles. Mayby it’s time to try out another sofware…;(
I’m a bit unclear to which component in your model you’re having issues with. It’d help if you had an example model with only the ones that where relevant.
Another thing - I notice your geometry is a far way from the origin of the model (where the axis are) This can very easily cause issues in SketchUp. It’s recommended that you keep geometry close to the origin. And if you need the model to be relative to world location use the georeference tool.
Can you copy the mesh you have problem with into a separate file so we are sure we’re talking about the same thing?
Getting an exception on a base model. Can supply the SKP for example. It’s just a simple box 52mm x 100mm on the outside, end walls 5.5mm thick, sides 2mm thick. Put 2.5mm deep holes in the ends 5mm in from the outer edge. Floor of the box is 2mm thick. Did an inspection just because well I do it every so many changes. Exception generated below.
Solid Inspector² (2.2.1)
Extension Path: C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins
SketchUp Version: 15.2.685 (64bit)
Ruby Version: 2.0.0
Ruby Platform: x64-mingw32
Error:
#<NoMethodError: undefined method `edges' for nil:NilClass>
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:149:in `find_start_face'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:39:in `block in resolve'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:72:in `find_geometry_groups'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:38:in `resolve'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:84:in `block (2 levels) in find_errors'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:258:in `call'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:258:in `time'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:82:in `block in find_errors'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:32:in `find_errors'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_tool.rb:234:in `analyze'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_tool.rb:386:in `block in create_window'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:95:in `call'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:95:in `block in trigger_events'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:94:in `each'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:94:in `trigger_events'
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:35:in `block in initialize'
SketchUp:1:in `call'
Loaded Features:
enumerator.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/enc/encdb.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/enc/iso_8859_1.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/enc/trans/transdb.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/rbconfig.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/compatibility.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/defaults.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/deprecate.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/errors.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/version.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/requirement.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/platform.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/specification.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/exceptions.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/defaults/operating_system.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_gem.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/langhandler.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/sketchup.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/clf_center_on_origin/clf_center_on_origin_data.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/clf_center_on_origin/clf_center_on_origin_menus.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/clf_center_on_origin.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning/main.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SimLabIGESImporter/SimLabIGESImporter_loader.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SimLabIGESImporter.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SimLabOBJImporter/SimLabOBJImporter_loader.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SimLabOBJImporter.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SimLabStepImporter/SimLabStepImporter_loader.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SimLabStepImporter.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/translator.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/utils.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/webdialog_extensions.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/importer.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/version.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/debug.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/enum.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/enum_system_color.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/enum_system_font.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/events.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/font.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/json.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/properties.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/control_manager.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/typecheck.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/base.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/rect.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/control.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/button.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/checkbox.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/container.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/groupbox.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/image.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/label.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/listbox.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/radiobutton.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/textbox.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/bridge.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/window.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/core.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/exporter.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl/loader.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-stl.rb
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_advancedcameratools/advancedcameratools_main.rbs
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools/actloader.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools.rb
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcfunctions_v1.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclassifier.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_overlays.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dctools.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcutils.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcconverter.rbs
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents.rb
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/geometryhelpers.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/fromcontours.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/triangulatorutility.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/meshhelpers.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/fromscratch.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/smoovetool.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/stamptool.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/drapetool2.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/detailtool.rbs
c:/users/scott/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/flipedgetool.rbs
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_sandbox/sandboxmenus.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_sandbox.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_webtextures/webtextures_loader.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_webtextures.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/enc/trans/single_byte.so
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/system.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/enc/utf_16le.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/enc/trans/utf_16_32.so
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/arc.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/attributes.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/babelfish.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/libraries/2.10.0/2.0/win64/tt_lib2.so
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/bezier.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/binary.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/boolean_attributes.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/bounds.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/color.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/cursor.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/fiddle.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/fiddle/function.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/fiddle/closure.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/fiddle.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/fiddle/types.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/fiddle/value.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/fiddle/pack.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/fiddle/struct.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/fiddle/cparser.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/fiddle/import.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/win32_shim.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/dl.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/dl.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/Win32API.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/win32.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/debug.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/deferred_event.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/definition.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/dimension.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/draw_cache.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/point3d_ex.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/point3d.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/sketchup.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/progressbar.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/edges.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/instance.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/entities.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/geom3d.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/uvq.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/faces.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/length.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/locale.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gl_image.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/javascript.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/json.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gui.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/image.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/modal_wrapper.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/webdialog_patch.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/window.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/toolwindow.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/settings.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/inputbox.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/materials.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/metaclass.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/model.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/profiler.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/ray.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/selection.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/simpletask.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/toolbarwindow.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/uv_plane.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/version.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_cleanup/core.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_cleanup.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/set.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl_helper.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/errors.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/instance.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/debug_tools.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/json/version.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/ostruct.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/json/generic_object.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/json/common.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/enc/utf_16be.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/enc/utf_32be.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/enc/utf_32le.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/json/ext/parser.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific/json/ext/generator.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/json/ext.rb
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/json.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_window.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/geometry.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_window.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/key_codes.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/drawing_helper.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/object_utils.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/label.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/cache.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/types.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/file.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/struct.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/image_bmp.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/pixelcache.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/image.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/text.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/legend.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/settings.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/core.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/smustard_Weld/weld.rb
C:/Users/Scott/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/smustard_Weld.rb
zant
February 2, 2015, 9:18am
69
Hi there. I prepared a new file. Sorry for this mess. Is there any hope to make it work?
https://drive.google.com/file/d/0B5XpTM6k3ud9RW5NU0hnZTJFYkU/view?usp=sharing
Solid Inspector² (2.2.2)
Extension Path: /Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins
SketchUp Version: 15.1.104 (64bit)
Ruby Version: 2.0.0
Ruby Platform: x86_64-darwin12.5.0
Error:
#<TypeError: wrong argument type (expected Sketchup::Face)>
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:98:in `reversed_in?'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:98:in `edge_reversed_in?'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:205:in `get_other_face'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:221:in `find_other_shell_face'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:286:in `block (2 levels) in find_shell'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:282:in `each'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:282:in `block in find_shell'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:281:in `each'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:281:in `find_shell'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:41:in `block in resolve'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:74:in `find_geometry_groups'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:38:in `resolve'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:84:in `block (2 levels) in find_errors'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:258:in `call'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:258:in `time'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:82:in `block in find_errors'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:32:in `find_errors'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_tool.rb:234:in `analyze'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_tool.rb:386:in `block in create_window'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:95:in `call'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:95:in `block in trigger_events'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:94:in `each'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:94:in `trigger_events'
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:35:in `block in initialize'
Loaded Features:
enumerator.so
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/encdb.bundle
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/trans/transdb.bundle
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/rbconfig.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/compatibility.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/defaults.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/deprecate.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/errors.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/version.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/requirement.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/platform.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/specification.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/exceptions.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_gem.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/langhandler.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/sketchup.rb
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_advancedcameratools/advancedcameratools_main.rbs
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools/actloader.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools.rb
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcfunctions_v1.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclassifier.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_overlays.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dctools.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcutils.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcconverter.rbs
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents.rb
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/geometryhelpers.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/fromcontours.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/triangulatorutility.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/meshhelpers.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/fromscratch.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/smoovetool.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/stamptool.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/drapetool2.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/detailtool.rbs
/users/misratasci/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/flipedgetool.rbs
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_sandbox/sandboxmenus.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_sandbox.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_webtextures/webtextures_loader.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_webtextures.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/system.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/arc.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/attributes.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/babelfish.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/libraries/2.10.0/2.0/osx64/tt_lib2.bundle
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/bezier.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/binary.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/boolean_attributes.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/bounds.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/color.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/cursor.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/win32.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/debug.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/deferred_event.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/definition.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/dimension.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/draw_cache.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/point3d_ex.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/point3d.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/sketchup.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/progressbar.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/edges.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/instance.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/entities.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/geom3d.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/uvq.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/faces.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/length.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/locale.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gl_image.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/javascript.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/json.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gui.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/image.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/modal_wrapper.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/webdialog_patch.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/window.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/toolwindow.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/settings.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/inputbox.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/materials.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/metaclass.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/model.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/profiler.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/ray.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/selection.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/simpletask.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/toolbarwindow.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/uv_plane.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/version.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/win32_shim.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/set.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl_helper.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/errors.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/instance.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/debug_tools.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/version.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/ostruct.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/generic_object.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/common.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_16be.bundle
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_16le.bundle
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_32be.bundle
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_32le.bundle
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/json/ext/parser.bundle
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/json/ext/generator.bundle
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/ext.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_window.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/geometry.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_window.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/key_codes.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/drawing_helper.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/object_utils.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/label.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/cache.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/types.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/file.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/struct.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/image_bmp.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/pixelcache.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/image.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/text.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/legend.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/settings.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/core.rb
/Users/misratasci/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2.rb
sroyalty:
@sroyalty - I believe this error is already fixed in version 2.2.2. Please update to the latest version and try again.
@misratasci - Can you share the model where this happened?
The code I am leaving is too long for a single message so I have split it into 2 posts. I hope that works ok for you.
Extension Path: /Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins
SketchUp Version: 15.2.686 (64bit)
Ruby Version: 2.0.0
Error:
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:98:in `reversed_in?'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:98:in `edge_reversed_in?'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:205:in `get_other_face'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:221:in `find_other_shell_face'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:286:in `block (2 levels) in find_shell'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:282:in `each'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:282:in `block in find_shell'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:281:in `each'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:281:in `find_shell'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:41:in `block in resolve'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:74:in `find_geometry_groups'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:38:in `resolve'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:84:in `block (2 levels) in find_errors'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:258:in `call'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:258:in `time'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:82:in `block in find_errors'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:32:in `find_errors'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_tool.rb:234:in `analyze'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_tool.rb:386:in `block in create_window'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:95:in `call'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:95:in `block in trigger_events'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:94:in `each'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:94:in `trigger_events'
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb:35:in `block in initialize'
Loaded Features:
enumerator.so
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/encdb.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/trans/transdb.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/rbconfig.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/compatibility.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/defaults.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/deprecate.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/errors.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/version.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/requirement.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/platform.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/specification.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/exceptions.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_gem.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/langhandler.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/sketchup.rb
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/sketchucation/!scfapitools.rbs
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/common.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/generic.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/ftp.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/http.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/https.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/ldap.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/ldaps.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/mailto.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/stringio.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/date_core.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/date/format.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/date.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/time.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/open-uri.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/socket.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/socket.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/timeout.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/protocol.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/zlib.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/exceptions.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/header.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/generic_request.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/request.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/requests.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/response.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/responses.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/proxy_delta.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/backward.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/iso_8859_1.bundle
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/SCF-myShortcuts.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/SCF-openPluginsFolder.rb
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/sketchucation/scf-rbztools.rbs
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/delegate.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/thread.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/singleton.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/etc.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/fileutils.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/tmpdir.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/tempfile.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/dos_time.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/ioextras/abstract_input_stream.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/ioextras/abstract_output_stream.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/ioextras.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/entry.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/generic.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/universal_time.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/old_unix.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/unix.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/zip64.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/zip64_placeholder.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/entry_set.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/central_directory.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/file.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/input_stream.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/output_stream.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/decompressor.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/compressor.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/null_decompressor.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/null_compressor.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/null_input_stream.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/pass_thru_compressor.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/pass_thru_decompressor.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/inflater.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/deflater.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/streamable_stream.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/streamable_directory.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/errors.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip.rb
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/sketchucation/scf_manager.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/sketchucation/scf_uninstaller.rbs
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/sketchUcloud.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/SCF_loader.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/!SketchUcation_loader.rb
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/langhandler.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/artisan.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/artisantools.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/extrude_tool.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/polyreduce.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/proxy_settings.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/tool_observer.rbs
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/DM_artisan/artisan_load.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/DM_artisan.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/fixSolid/fixSolid.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/fixSolid_loader.rb
Part deux…
LibTraductor.rb
libtraductor.rb
LibFredo6.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6__obsolete.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6_API.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6_txtmsg.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Algo.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6AllPlugins.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Config.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Contour.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6DirectionManager.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6EdgePicker.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Error.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6FacePicker.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6G6.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Input.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Magnifier.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Mark.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Material.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Offset3d.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Opengl.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Operation.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6OriginTargetPicker.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Palette.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6PaletteHelper.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6PluginDialogs.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Profile.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Protractor.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Registry.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Selmode.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Spline.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Startup.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Stencil.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6StencilIntersector.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6StencilManager.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6System.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Tool.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Transform.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Translate.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Upgrade.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6VCB.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6WebHtml.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6WebJS.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6WebWdlg.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6WebXTable.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/__loader.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/__loader.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/bootstrap_RoundCorner.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/__loader.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_ToolsOnSurface/bootstrap_OnSurface.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_ToolsOnSurface/__loader.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/utils_stairs.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/stairlib.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/license_stairs.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/stair_rules.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/stair_defaults.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/stairmakerlib.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/treadlib.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/riserlib.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/stair_checks.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/stair_gui.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/stairmaker.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/gkware_stairmaker/stair_2d.rbs
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/gkware_stairmaker/gkware_stairmaker_loader.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/gkware_stairmaker.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/smustard_DropGC/DropGC.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/smustard_DropGC.rb
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_advancedcameratools/advancedcameratools_main.rbs
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools/actloader.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools.rb
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcfunctions_v1.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclassifier.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_overlays.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dctools.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcutils.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcconverter.rbs
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents.rb
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/geometryhelpers.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/fromcontours.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/triangulatorutility.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/meshhelpers.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/fromscratch.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/smoovetool.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/stamptool.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/drapetool2.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/detailtool.rbs
/users/teacher/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/flipedgetool.rbs
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_sandbox/sandboxmenus.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_sandbox.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_simplify_contours/simplify_contours.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_simplify_contours.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_webtextures/webtextures_loader.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_webtextures.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TIG-weld.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/system.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/arc.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/attributes.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/babelfish.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/libraries/2.10.0/2.0/osx64/tt_lib2.bundle
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/bezier.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/binary.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/boolean_attributes.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/bounds.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/color.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/cursor.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/win32.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/debug.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/deferred_event.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/definition.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/dimension.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/draw_cache.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/point3d_ex.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/point3d.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/sketchup.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/progressbar.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/edges.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/instance.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/entities.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/geom3d.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/uvq.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/faces.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/length.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/locale.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gl_image.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/javascript.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/json.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gui.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/image.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/modal_wrapper.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/webdialog_patch.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/window.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/toolwindow.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/settings.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/inputbox.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/materials.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/metaclass.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/model.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/profiler.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/ray.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/selection.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/simpletask.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/toolbarwindow.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/uv_plane.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/version.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/win32_shim.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_EdgeTools/divider.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_EdgeTools/close_gaps.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_EdgeTools/simplify.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_EdgeTools/make_colinear.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_edgetools/core.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_edgetools.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector/upgrade.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector/core.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/set.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl_helper.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/errors.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/instance.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/debug_tools.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/version.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/ostruct.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/generic_object.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/common.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_16be.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_16le.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_32be.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_32le.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/json/ext/parser.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/json/ext/generator.bundle
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/ext.rb
/Applications/SketchUp 2015 (English)/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_window.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/geometry.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_window.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/key_codes.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/drawing_helper.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/object_utils.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/label.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/cache.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/types.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/file.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/struct.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/image_bmp.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/pixelcache.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/image.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/text.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/legend.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/settings.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/core.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2.rb
/Users/teacher/Library/Application Support/SketchUp 2015/SketchUp/Plugins/utilities_10.rb
cheers
This should be the model.
new build.skp (459.9 KB)
@funkicks - this looks to be the same error as @misratasci report. I’m adding your sample model to the issue tracker:
https://bitbucket.org/thomthom/solid-inspector/issue/30/reversed_in-fails-with-this-model
Thank you very much for providing this report and sample model. It makes it easier for me to figure out he source of this error.
Extension Path: /Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins
Ruby Version: 2.0.0
Error:
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:98:in `reversed_in?'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:98:in `edge_reversed_in?'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:205:in `get_other_face'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:221:in `find_other_shell_face'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:286:in `block (2 levels) in find_shell'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:282:in `each'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:282:in `block in find_shell'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:281:in `each'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:281:in `find_shell'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:41:in `block in resolve'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:74:in `find_geometry_groups'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb:38:in `resolve'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:84:in `block (2 levels) in find_errors'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:258:in `call'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:258:in `time'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:82:in `block in find_errors'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb:32:in `find_errors'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_tool.rb:234:in `analyze'
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_tool.rb:111:in `onLButtonUp'
Loaded Features:
enumerator.so
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/translator.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/utils.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/webdialog_extensions.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/importer.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/version.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/debug.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/enum.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/enum_system_color.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/enum_system_font.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/events.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/font.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/json.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/properties.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/control_manager.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/typecheck.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/base.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/rect.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/control.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/button.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/checkbox.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/container.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/groupbox.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/image.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/label.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/listbox.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/radiobutton.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/textbox.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/bridge.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/window.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/SKUI/core.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/exporter.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl/loader.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/sketchup-stl.rb
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_advancedcameratools/advancedcameratools_main.rbs
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools/actloader.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools.rb
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcfunctions_v1.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclassifier.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_overlays.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dctools.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcutils.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcconverter.rbs
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents.rb
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/geometryhelpers.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/fromcontours.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/triangulatorutility.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/meshhelpers.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/fromscratch.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/smoovetool.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/stamptool.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/drapetool2.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/detailtool.rbs
/users/chrismoorehead/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/flipedgetool.rbs
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_sandbox/sandboxmenus.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_sandbox.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_webtextures/webtextures_loader.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_webtextures.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl_helper.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/errors.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/instance.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/debug_tools.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_window.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/geometry.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_window.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/key_codes.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/drawing_helper.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/object_utils.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/label.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/cache.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/types.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/file.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/struct.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/image_bmp.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/pixelcache.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/image.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/text.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/legend.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/settings.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/core.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/path_support.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_edgetools/core.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_edgetools.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/system.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/etc.bundle
/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/fileutils.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/arc.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/attributes.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/babelfish.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/libraries/2.10.0/2.0/osx64/tt_lib2.bundle
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/bezier.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/binary.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/boolean_attributes.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/bounds.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/color.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/cursor.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/win32.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/debug.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/deferred_event.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/definition.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/dimension.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/draw_cache.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/point3d_ex.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/point3d.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/sketchup.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/progressbar.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/edges.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/instance.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/entities.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/geom3d.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/uvq.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/faces.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/length.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/locale.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gl_image.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/javascript.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/json.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gui.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/image.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/modal_wrapper.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/webdialog_patch.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/window.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/toolwindow.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/settings.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/inputbox.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/materials.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/metaclass.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/model.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/profiler.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/ray.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/selection.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/simpletask.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/toolbarwindow.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/uv_plane.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/version.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/win32_shim.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_cleanup/core.rb
/Users/chrismoorehead/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_cleanup.rb
No worries Thom.
I am getting loads of surface boarder errors coming up that require me to resolve them.
I can’t see how this is done or why they are coming up as I think the model is quite simple. Can you help? new build2.skp (687.8 KB)
Notice that not all of them are surface borders, only a few. Most of them are edges that are connected to internal faces. If you click on each category you can filter out the viewport highlighting.
Notice the Surface Borders section, this means you have some edges that connect only to one face - meaning there is a hole. When you have holes it’s not possible to reliably detect internal faces or reversed faces.
So you want to make sure to remove that stray rectangle and close up the hole underneath the stairs. Once you have done that Solid Inspector should be able to find your internal faces.
@chris_moorehead - thanks for reporting. Wow, that’s four reports within the same weeks of the same problem, and no-one else reported it before. I wonder why there is such an influx now…
Btw, Chris, can you share the model where this happen with me?
Error report:
This is a model I got from 3D warehouse: Music Chair . When I click on the back of the chair (a group), I get an “uncaught error”.
The text was too long for the forum. I’ve saved it here: pastebin
Hey there. I have been trying to get my solid to be watertight in order to 3D print but i keep on running into problems with it not registering as a complete solid. I downloaded the solid inspector and it helped with some of the issues but i keep getting “Surface borders” and “internal surface edges” errors when i use it. If there is anyway this can be fixed that would be great. I can post the model here or a screenshot for anyone to look at.
