Lulwa
#1
I have been trying to render in vector the solid fill scene created in Sketchup.
In sketchup, the style i have created has no edges or profiles (all line work off) and only solid fill On.
The scene in sketchup looks exactly like i want it. But when i render it in vector settings in layout, the viewport shows all the edges again.
How can i fix this issue?
DaveR
#2
Vector rendering by definition will show vector edges. If you don’t want the edges to show, leave the rendering set to Raster.
Lulwa
#3
I want it vector so it renders the solid fill line and be able to export it to dwg
DaveR
#4
Upload an example LayOut file.
Lulwa
#5
section fill issue.layout (103.3 KB) Here is a sample.
DaveR
#6
So you want it like on the right?
Group from slice is designed for that sort of thing.
JQL
#7
I also have issues with this. Sketchup and Hybrid/Vector are not 100% match and should be.
These particular scenarios would be very useful to have in Layout for Vector/Hybrid drawings but you can’t:
- Profiles ON Edges OFF Faces ON
- Profiles ON Edges OFF Faces OFF
- Profiles OFF Edges OFF Faces ON
Raster drawings are not good for DWG, or PDF vector drawings export
Lulwa
#8
Yes but thats extra steps and not automated like the one I was trying to implement
DaveR
#9
But it works and gets you what you asked for.
