All the shapes that I would like to use procedural follow me have curves which create lots of visible lines when creating a follow me shape - easily hidden with soften edges, but it seems you can’t soften the edges of a procedural follow me object. is this likely to be added as a feature?
Weld the edges before running or re-running Follow Me, either normal Follow Me or Proceduaral Follow Me.
Superb, thank you!
You’re welcome. You might find it worthwhile to set up a keyboard shortcut for Weld Edges. Also keep in mind that you may not want to weld all of the edges in the profile. Here I have a crown molding profile in which the curves are exploded. I selected only the curves and used the keyboard shortcut to weld them.
Since Weld Edges is a Context menu item you need to have a sequence of edges selected before the command will appear in Preferences>Shortcuts.
