You could add details to the surface but it’s probably not worth the time. Use a texture instead. If you’re going to continue modeling the way you’ve started in your latest file, I think you’d also find it worthwhile scaling up. Scale your model up so 1 inch is 1 meter, change the units to meters and proceed. This will help you get around the tiny face limitations.
Eye, brow and other surface detail delineating the body characteristics. I hate to ask this but I went into Window Model Info and Units to change to decimals. Where do I find proportion?
There is no “proportion” as such. Use the Scale tool to scale the model up or easier, use the Tape Measure tool. Measure the distance between two points making sure you click on each point. If the distance is 3 inches type 3m and hit Enter. That’ll scale the model up so 3 inches is 3 meters. Change units to Meters.
