Smoothing Between Objects
Is there a way to smooth between two objects that intersect at a hard angle? Would like to smooth the hard edge where the mesh and egg meet.
52%20AM
Check out the extension FredoCorner
Unfortunately it won’t work with faces.
12%20PM
Upload the SKP file.
Probably there are better ways than this one using follow me tool.
After creating it you can scale it and smooth the edges.
Look underneath, you likely need to loose the face under the dome so that your new selection is an edge.
