SmartWindowBuilder: find every opening and place parametric windows & doors in one click
Hi everyone,
I’m the developer of DWG to 3D, and this is my second extension: SmartWindowBuilder. It reads the walls you select (or the whole model), finds the window and door openings and fills them with real, editable windows and doors, in one click and one undo step.
What it finds
  • Holes in wall faces, and gaps between separate wall pieces under a lintel
  • Multi-storey buildings, floor by floor
  • Size, sill height, wall thickness and the inside/outside of each opening (flip with one click)
  • Works on any model. If it was made with DWG to 3D, it also reads its lintel data (not required)
What it builds
  • 13 window and door types: casement (tilt & turn), double casement, fixed, sliding (1–6 panels), folding, divided, top/side lights, glazing bars, balcony door, French balcony, interior door, double door, entrance door
  • Three detail levels: mitred frames, glazing beads, double glazing, gaskets, hinges, handles, or a light version for big projects
  • Marble sills with a drip groove; door swing arcs and opening symbols for plans
  • Reusable components (same size = one definition); your own materials and geometry are never touched
The panel: pick types by picture, live elevation, live preview in the model before anything is created. Change the colour once and every window follows. English & Turkish interface.
Requirements: SketchUp 2021 or newer. Tested on Windows; feedback on Mac and newer versions is very welcome.
Questions, bug reports and feature requests are welcome in this thread. Thanks!
