I have SKU 2018 on a previous laptop and I now have a 2019 MacBook Pro that I want to use my 2018 version on as the battery is no longer working. I have transferred the application using a flash drive but when I try to open it up it doesn’t work. I have been in touch with Trimble and they are not aware of anyway that I can get the licence page open to enable it to work. I know that they do not support this older version and have moved to a subscription based system.
I am now retired from my business where I used to use SKU but only now need it for my personal use alongside Layout which I know is not available with the newer online web based version.
Does anyone know anyway I can solve this situation. I am not a computer wizard so need any explanation to be in as simple a way as possible.
I would be extremely grateful if anyone can help in anyway at all
Hi, I’m sorry you’re stuck. I can’t promise a fix, but here are the things I’d try, in simple steps.
1. Check whether the old laptop still works with the charger plugged in.
A dead battery usually doesn’t stop a laptop from running on mains power. If it switches on, you could keep using SketchUp 2018 and Layout there. This is the easiest option if it works.
2. Install SketchUp again instead of copying it.
On a Mac, copying the program across on a flash drive often doesn’t work, because it needs to be installed properly. Look for your original SketchUp 2018 installer, either from the original download or an old email. Run that installer on the MacBook.
3. Find your licence details.
SketchUp 2018 is activated with a serial number and an authorization code. These may be in:
your original purchase email,
your Trimble/SketchUp account (log in on their website and look for your licences), or
the old laptop, under the Help menu, then License.
Enter these on the new Mac when it asks you to activate. If you can’t find them, tell Trimble you have a 2018 licence you own and ask them to look the details up using the email address on your account.
4. Check your Mac’s system version.
SketchUp 2018 was made for older versions of macOS, so on a newer Mac it can behave strangely. Click the Apple menu, then “About This Mac”, and note the macOS version. Anyone replying here can then tell you whether 2018 is likely to run on it.
If it still won’t open, please post any error message word for word, or take a screenshot. That will help people here work out what’s going wrong.
I’ve looked back through all my old emails looking for the installer link but to no avail. Either the links don’t work or they’ve expired. Any links to Trimble no longer have any support from this older version so I don’t have the original installer or access to it. The only possibility is that it will be in a file somewhere on my old laptop as part of the SKU program files but don’t know what the file might be called…
I have the licence serial number and authorisation code. I have asked Trimble to look up the 2018 licence but they have drawn blank. And when I try to run SKU it doesn’t get to the activation screen for me to enter licence etc
The file size Ive just noticed when I tried to open it is only 366KB !! That can’t be correct as Layout and Style Builder and over 300 MB each so maybe there are more files somewhere to be copied ?
And when I try to open SKU this is a screenshot of just part of the error message…
SketchUp 2018 was developed and released in the ol’ Sierra & High Sierra days.
Google Gemini agrees:
Manually copying application files over on macOS will break things because Mac apps rely on installer packages (.dmg or .pkg) to deploy companion frameworks, preference files, and support libraries into system library paths (/Library, ~/Library). Simply dragging an app bundle across won’t register those dependencies.
Furthermore, SketchUp 2018 is heavily outdated for macOS 15 (Sequoia)—it predates modern requirements by many years and relies on legacy frameworks that can cause crashes, licensing server communication failures, or outright launch blocks.
To fix this, the user needs to properly locate or re-download the original SketchUpPro-2018.dmg installer package rather than trying to salvage a manual file copy.
Additionally, the Trimble license servers are still having problems with 2017 and 2018.
Click on your avatar at the top right of the forum page. Click on the person icon, then Preferences, and Profile. Complete all of the fields with the correct information and then scroll to the bottom to click the Save button.
