Hello,
The dimension toolbar has disappeared. Can someone kindly advise how I may recover this. Obviously it is not a constituent of the Default Tray
Many thanks.
Hello,
Many thanks.
What does the dimension tool bar have to do with VRay?
Which dimension tool bar are you missing?
The toolbar has nothing to do with Vray but is a fundamental part of Sketchip
Many thanks
You can switch on and of the different toolbars if you go to menu View>>Toolbars...
Dimension related toolbar items are included in Toolbars named âConstructionâ and âLarge Tool Setâ by default. If you chaged them, you can reset it in the above-mentioned dialog.
See also:
Toolbars
Customizing Toolbars and Menus
Ps: As Dave pointed out - if you mean Dimension as Measurements- there is a dedicated Measurements Toolbar too. (If you activate that Toolbar, it will disable Measurements label and value / VCB/ , then you need to manually reactivate it as Dave shows.)
_
The Trays can be managed by menuWindow>>Manage Trays... and does not contains any Toolbar item.
Hello
Thanks for this
Sorry I should have put Sketchup Studio
I have now located it.
Best wishes
I made it for you⌠![]()
