But why do all that zipping work ? Does the following do the same ?
def center_model_on_ORIGIN(op_name="Center Model")
model = Sketchup.active_model
center = model.bounds.center
vector = Geom::Point3d.new(center.x,center.y,0).vector_to(ORIGIN)
model.start_operation( op_name, true, false, true )
model.entities.transform_entities(vector,model.entities.to_a)
model.pages.each do |page|
cam = page.camera
cam.set(
cam.eye.transform!(vector),
cam.target.transform!(vector),
cam.up # use the same up
end
model.commit_operation
end ### center_model_on_ORIGIN
EDIT: Removed the call to page.update
within the block.
(As this would set all page cameras to whatever the current camera is.)
@DanRathbun @john_drivenupthewall Thank you for all the effort. I will apply the code to our model today and let you guys know how it works.
Really, really appreciate!
Be safe. Try it on a backup copy first.
@DanRathbun @john_drivenupthewall Problem solved!!! I gave solution to Johnās original code, but what actually worked is a combination of Danās and Johnās code below. Kudos to both you guys!!!
vec = Geom::Point3d.new(center.x,center.y,0).vector_to(ORIGIN)
vec,model.entities.to_a)
stp_r, stp_g, stp_b = vec.to_a.entries
# then
pages = Sketchup.active_model.pages
# camera
cam = page.camera
# camera target
target = cam.target
# camera eye
eye = cam.eye
# camera up
up = cam.up
# get arrays
e0 = eye.to_a
t0 = target.to_a
# use standard ruby on target position
t = t0.zip([stp_r, stp_g, stp_b]).map(&:sum)
# eye positions
e = e0.zip([stp_r, stp_g, stp_b]).map(&:sum)
# use the same up
cam.set(e, t, up)
end #pages.each
how was the speed?
can you run a timing on both versions for our curiosityā¦
# at the top
t1 = Time.now
# at the end
Time.now - t1
just swap the coreā¦
# swap this
e0 = eye.to_a
t0 = target.to_a
# eye positions
# use the same up
cam.set(e, t, up)
### for this
cam.set(
do a restart in between runs of fresh copies of the same skp fileā¦
and maybe add some model statisticsā¦
john
The update speed was instant.
I would like to try, however Danās code core couldnāt run on my SketchUp 2019 when I tested. I ended up only using part of his on centering the model.
Did you get an error? What was it?
Dan,
I didnāt get any error. It just ran the code and returned no visual change before/after.
Thanks.
Was this before or after I fix the code by removing the page.update
call ?
Ie ā¦
Was after you removed the call.
Can you post a test model with all the camera scenes before the move operation ?
I had to convert it to v2018. But I do not see any scene pages in this model.
You said you had scenes, ā¦
Some were 3 pt perspective and some where 2 pt perspective and some may have been orthogonal ?
It is the adjustment of your scenes that is the main issue.
Below is the 2018 version of the test model I converted. Yes, this is my test model which should have 2 scenes in it. Our project model has tons of scene, I didnāt send you for confidential concern. However I guarantee the code behave the same in both models.
Test model 2018 Version
Best,
Shuojin
@john_drivenupthewall @DanRathbun
Hi Dan and John,
There is one more little question.
We got the code working perfectly for the purpose. I have been thinking about how to execute centering of the model process. Since not only we have multiple people team, we have multiple models (around 20): elevation exports, individual building model, animation model, aerial view model, etc,. And we have a lot of archived versions of each. Is there an effective way, by adding something to the code, to leave marks after the centering is done (for example to generate a layer of certain name) to inform the team members visually, as well as to inform the code itself not to run twice? What would you guys usually do?
Thanks a lot,
Shuojin
you can tag the model fileā¦
tested codeā¦
def test_tag
# at the top
done = Sketchup.active_model.get_attribute('JcB', 'cams_moved')
return 'already processed' if done
# <code>
p 'new_file'
# at the end of the code you add...
Sketchup.active_model.set_attribute('JcB', 'cams_moved', true)
end
the script will only run once per fileā¦
john
@john_drivenupthewall The core works as used alone, but it doesnāt return anything once I combined the code. Appreciated, could you please help take a quick look at the code?
def test_tag
# at the top
# <code>
vec = Geom::Point3d.new(189600,169200,0).vector_to(ORIGIN)
# then
# camera
cam = page.camera
# camera target
target = cam.target
# camera eye
eye = cam.eye
# camera up
up = cam.up
# get arrays
e0 = eye.to_a
t0 = target.to_a
# eye positions
# use the same up
cam.set(e, t, up)
end #pages.each
p 'new_file'
Sketchup.active_model.set_attribute('JcB', ' cams_moved', true)
end
