Sketchup pro keep not responding when export to dwg
i tried to export 1 of my scene to dwg, but it keeps not responding, can u tell whats wrong or i just have to be patience? here i attach my model
skp file
How long did you wait? Your file is very obese, with almost 30 million entities.
Exporting to DWG might take a long time, possibly overnight. It would help if you simplified your overly detailed furniture and entourage components.
i only wait like 5 hours, how do i simplified my file??
Get rid of stuff that isn’t really needed. Maybe the overly detailed back on the floor.
Or the cacti on the desks. Simplify the display arms. Do you really need the details in the clamps, for example?
Use lower-poly furniture. Do the creases in the upholstery on the chairs and other furniture really add useful information to your model?
Simplify the couches.
You should also go through and clean up the exposed back faces (in blue). On the table legs here, for example.
You should also ensure you are using tags correctly. All edges and faces should be created and remain untagged. Only groups and components should be given tags.
If you are exporting a 2D dwg of the elevation from Scene 4, turn off the tags for all of the furniture behind the walls so the exporter doesn’t have to waste time exporting content that won’t show.
Thank you, i can export it now
