All of my new and historic files are now opening in a see through like mode. This happens with formerly saved files as well as new one. When I open a new file the human figure in the file shows only as an outline and doesn’t cast a shadow. If I double click on the figure to get in into and edit mode, then the figure’s normal coloring shows, but as soon as I click out of the edit mode it returns to a see through outline. This is also true for all other grouped objects in the file as well Masukawa Room Layout.skp (3.2 MB) Room
hello, sounds like a graphic driver issue. did you try to update your amd drivers ?
Thanks Y’all…I will try updating the driver to see if that corrects the problem.
A big THANKS for the GPU driver update suggestions. It did the trick!!
