Awk! I’m on a PC using SketchUp Pro 2020, and I only have three days left of my free trial!
I’m taking the Lynda course “Modeling a Lamp.” For the second time, I can’t see the bottom of the model, using either the camera view or the orbit tool. The first time, it just as suddenly started behaving properly as it had stopped.
When I use the orbit tool I can get to the side view, but when I try to move lower the screen goes white. I zoom out and find myself looking at the top view. The same thing happens when I use Camera>Standard View>Bottom.
I can’t find anything in the Preferences or Model Info to control this.
Time is unfortunately of the essence here. This is a kind of major problem, and with only 3 days left of my free trial I need to know I can eliminate this issue before I spend the scads of money SketchUp Pro costs.
I can rotate in every view but the bottom, and the axes rotate along with the model.
If I have the Select tool selected, when I click on the empty space and right click my options are Invert Selection, make Component…, and Make Group.
If I have the Orbit tool selected and right-click in the empty white space I have Exit, Orbit, Pan, Look Around, Walk, Look Around, Zoom, Zoom Window, and Zoom Extents
Oh, sorry, it took a while for all the text you wrote to be visible. I created it improperly, now I understand. MANY thanks.
I tried it several times, too, following the instructions, and I did get a warning message each time…but since I got the Follow Me tool to do anything at all I just tried to go on. The course is for SketchUp 2019, but I didn’t think there could be that much difference between the two versions. I also couldn’t get the centered circle where you see the hole to work his way, but instead found the center of the base’s top square with the tape measure tool and used the circle from there. (The instructor said to find the center of the square’s two sides using the shift key).
Then I tried copying the original into the file you made, and NEITHER geometry could be seen from the bottom. I had to delete the copy to see your geometry from the bottom.
If I DELETE the copy from my orginal file that I pasted into yours I can no longer see the bottom of your geometry. I have to Control+Z to eliminate my copy. Then yours works perfectly.
I just tried editing the component and selecting all of it, and dropping it in your file, and it still didn’t work. Can you telling me how you did that?
