Windows 11 26H2
Processor: AMD Ryzen 9 9955HX
Sketchup Pro 2027
Open Sketchup - it does not comply with the run in Maximized window setting in the shortcut. It starts as full screen, then jumps to a windowed screen. Model Info window opens to the size of the SU window. Move Model Info, close it, and reopen it—it retains its position. Exit and restart SketchUp—Model Info loses its position and centers on screen. Other floating windows restore correctly.
Middle screen holds main Sketchup window. Right screen holds trays, Model Info dialog, other tools. I move Model Info to its desired location on right screen. Close and open it with SU active and it locates properly. Close SU and Model Info window is enlarged and centered on middle screen.
Private Preferences show the last saved position of Model Info correctly:
“ModelInfoDlg”: {“curPage”: 1, “cx”: 652, “cy”: 457, “show”: true, “x”: 4386, “y”: 30}
However, it does not open to the last location and size and the Main Sketchup window is not opening full screen as set by the shortcut.
Same behavior when I open from the Start menu.
VERY irritating.
Any constructive insights are appreciated.
