Sketchup-Layout Authorization problems with 2027 Mac version
I upgraded to SU & LO 2027. They worked fine on my Mac Studio on macOS 26.6.2. Yesterday, I upgraded my MacBook Pro to macOS 27.2.
When I attempted to install on my second device, the MBP, the sign-in claims that I have THREE AUTHORIZED DEVICES. I do not. I only have my two authorized devices.
If I attempt to clear the Authorizations, the page hangs indefinitely with the spinning icon.
How do I remove the extra authorizations if the normal way does not work? I do not want to risk affecting my Mac Studio since I am on a job.
I seemed to have resolved the issue. I launched SketchUp instead of Layout and the process behaved as expected. This bug seems to occur when trying to Authorize with Layout.
However, when I went back to my Mac Studio, I was told it was no longer authorized. Then I got a message that my subscription had expired (it has about 3 weeks left).
I opened a Tech Support ticket 6 hours ago and haven’t received a response.
Any suggestions appreciated.
Sign out of any instances of SketchUp 2026 and earlyier that you have installed on your computers. Then do a cold reboot of the computer followed by signing in to SketchUp 2027.
On the MBP you may have gone through the steps of deauthorizing other sign-ins, to make sure the MBP could sign in. Back on the Studio you should be able to sign in, as your second activation.
As Dave suggests, each version of SketchUp that has you still signed in counts against the number you can have. Opening every version of SketchUp (other than 2027) on both machines, and making sure you are signed out, will free up enough for both machines to use 2027.
Thanks gentlemen. This is very helpful and I will give it a go. It doesn’t explain why I got the message that my subscription had ended but I will take it a step at a time. I am frankly concerned that I will get locked out of an active job so I am reluctant to quit and reboot.
This is resolved. Thanks, Dave. Signing out of 2026 on both computers resolved the problem.
This actually started an interesting discussion with tech support about why we no longer have the ability to use two or more independent windows for multi-monitor use on the Mac. They confirmed the problem. Hopefully the programmers can give us back that ability.
