Hello all,
I can install all my extensions just fine, and everything appears to be good, with extension buttens showing and all. But when i hit a butten , nothing happens!
example: i wanna use “joint push pull” i select the object i want to push/pull, then I hit the button, and nothing happens.
Have you installed the latest version of
SketchUcation Toolset [v4.2.5] → SCF licensing dialog version as 5.4a
LibFredo [v12.8a]
etc
and restarted SketchUp afterwards ?
Then checked the validity of each of the licensed extensions…
Also please repeat what you show in your video with the Ruby Console open - that might include error messages
Has a solution been found to this issue. I am experiencing the same issue. Clicking on the toolbar or menu…nothing happens. Tried all of the above suggestions. All of the other Fredo6 plugins seem to be working ok.
