SketchUp 2027 (Mac): Save As dialog requires empty extension "." – cannot save as .skp
SketchUp 2027 (Mac): Save As dialog requires empty extension “.” – cannot save as .skp
SketchUp Pro 2027 (27.0.267), macOS [wersja], [MacBook Pro / Air, Apple Silicon], Polish system language.
When saving a new model with File > Save As, the macOS save dialog treats the required file extension as “.” instead of “.skp”:
  • Name “test1” → saved as “test1.” (no skp extension; Finder opens it in TextEdit)
  • Name “test3.skp” → rejected: “You cannot save this document with extension ‘.skp’. The required extension is ‘.’.”
  • Name “test.2” → rejected the same way.
The same happens in a local folder and in iCloud Drive. The saved files are valid SketchUp models (header shows 27.0.267) and open correctly after renaming to .skp. SketchUp 2026 on the same Mac saves correctly.
This problem is being worked on, and a fix is already found. The bug report in our system is SU-64319.
The next update we release should have the fix in it. I can’t yet give a date for when that will be.
Thanks
Thank You
