Sketchup 2027 Mac Mouse Scroll for Zoom too agressive
The zoom speed is redicuosly high wenn using it on macOS with the Magic Mouse. Please test.
Thanks
I do have a Magic Mouse somewhere I think! I use the trackpad on my MacBook Pro all the time. With two finger scroll the zooming in 2027 is smoother than 2026, but a lot faster. There is also pinch to zoom, that works at a gentle speed, and is super smooth. It takes some getting used to, but does let me zoom to what I want more exactly than in 2026.
Does the Magic Mouse have two finger pinch to zoom? If it does, try that.
This isn’t to say the zoom is ok. The desktop version should have this option that is in the web version:
@TedVitale_SU could pass on your comment to his team.
thanks; pinch to zoom on the trackpad indeed works good, but then one finger touch and move should orbit, and two finger touch and move should pan, than using the trackpad would be indeed a better way to navigate around (and my favorite way to go); using ctrl+command and the mouse and ctr+command+shift and the mouse was hard to learn but once learned it was the way to go; Pinch on the mouse dosen’t work…
One shortcut that I used a lot in 2026 and earlier, is control-command-drag. That gives a temporary orbit, much like middle mouse wheel. With 2027 that has been changed slightly, in that you don’t don’t have to press down. Hold control and command, then stroke the trackpad to orbit. Press and release shift to go in and out of pan.
thanks a lot, this makes more sense now…
Using macOS + Magic Mouse, most of the time that I need to use triple click I or simply moving and object or a line, I end up zooming away or in, also for the shortcuts I have to release the key otherwise is blocks, the workflow has become kind of slow and sluggish now. Is there a way to make it behave like sketchup 2026 or earlier?
Didn’t see that Device Sensitivity in the MacOS desktop version preferences.
When I said that desktop should have that setting, I meant it doesn’t at the moment, but it should be added as a feature.
please fix it asap, it is a real problem, it switched back to 2026 for now :frowning:
I’ll add a +1 on adding the web’s Device Sensitivity to Mac SU 2017.
The Mac’s SU 2026 trackpad two finger swipe for zooming wasn’t the best, but the new SU 2027 behavior is hyper sensitive and hard to use.
I had not tried the two finger pinch in/out gesture before, but it does give me much more control on the zoom function. I find the pinch gesture a little awkward right now, but I’ll get better with it. Still, the two finger up/down zoom gesture would be my preference if it had some sensitivity controls.
I’ve been a SU user for well over a decade and used a Logitech MX Master 3S mouse. Unfortunately, I’ve been forced to use my MBP trackpad with SU since I developed some physical issues that have me pretty much bed ridden. Using a mouse is problematic at best in a bed.
I had gotten reasonably proficient with the SU 2026 trackpad gestures for Pan (Shift-CTRL-CMD and single finger click and drag) and Orbit (CTRL-CMD and single finger click and drag). I also added a keyboard shortcut of ~ (the Tilda key) to activate the Orbit tool. In addition, with the Orbit tool active, adding the Shift key by itself switched Orbit to Pan as the Shift key does with the scroll wheel (middle) button on a mouse.
All that said, I do find the new SU 2027 trackpad gestures for Pan and Orbit are an improvement once you get use to them. The “trick” is to just do the single finger swipe while holding down CTRL-CMD or SHIFT-CTRL-CMD and not do the single finger tap and hold maneuver while Orbiting or Panning.
Is there a way to disable the Magic Mouse touch surface, until this is fixed up? Anyway the Magic Mouse is perfect for my workflow, it last ages and it have everything I need and I would like to not get any third party mouse just for Sketchup. The major problem is that everything I do I end up zooming in or out and it is really uncomfortable.
This may have always been there when using a Mac trackpad in SU, but I recently discovered that in addition to the two fingers on one hand pinch to zoom gesture, you can activate the zoom function using a single finger from both hands at the same time on the MBP trackpad.
Using two fingers, tap both in the middle-ish of the trackpad and slide them away from each other to zoom in. Tap them towards the outside-ish edges of the trackpad and slide them towards each other to zoom out.
For me, I’ve found the two handed two finger zoom gesture works better vs the one handed two fingers spread technique.
Note that this is a tap and swipe at the same time motion, not a tap, hold, and then swipe.
Also note that you must enable the Mac’s Settings → Trackpad → Zoom In or out option to get the one handed or two finger pinch gesture to be recognized at all.
I personally find more fast and precise ( at least it was on Su 2026 ) zoom in and out with one finger one Magic Mouse and keep the left hand on MBpro’s keyboard for shortcuts. Constantly moving back and forth trackpad and keyboard shortcuts maybe it can be done, but since is one more action to do it can be confusing but maybe with time it can be done, but the real problem now is, aside zooming in or out, everything I do with Magic Mouse, move , pan, select etc etc, it ends zooming in or out unwillingly, because the Magic Mouse’s touch surface has become way to sensitive.
