Sketchup 2027 importing DXF files
Hi guys,
by any chance any of you are having trouble importing DXF files? For instance in the 2026 version, I was able to import a 3D DFX file and see the full 3d model with its faces and lines.
But now with the 2027 version, when importing a DXF file I only get the outlines of the 3d model with no faces.
I just tried importing a 3D DXF file with SU2027 and this is what I got.
Can you show the import options you have selected?
before importing, check the options.
always check the options.
actually, there are new options for a better import of 3d dwg/dxf now, with better tesselation…
if it doesn’t comply, can we have a look at the file maybe ?
I noticed when testing DWG importing with an test file I made in AutoCad years ago that had examples of every 3D object type supported in AutoCad that everything else imported, with better results than in previous versions, but Mesh objects didn’t. That is a regression and I think the SU team is looking into it. Meanwhile, if you have the possibility, explode the meshes in your CAD app and they should import OK as single faces.
If possible, post a DXF file you are having problems with so others can try their luck with it.
Hi Dave, thanks for replying, the first pics are when using the 2026, the second pics with the 2027 version.I also tried changing the different options and I still got the same result with the 2027 version. So not sure what I am doing wrong.
Hi
this is the DXF file:
10232026-REF.dxf (706.2 KB)
Thanks
Hi Dave,
I posted some captures of the file and the options, on the comments.
Yes. I saw that. And I can duplicate the wireframe thing with your DXF file. Presumably you saw @ateliernab’s and @Anssi’s remarks?
After retiring I have no longer access to AutoCad so I don’t know what actually is happening, but I opened the DXF in Rhino and exploded all blocks there. After that I exported the model as DWG and imported that into SketchUp, and got this. I am guessing it is either a matter of meshes or then anonymous blocks (but they shouldn’t have worked in older versions either).
Untitled.skp (43.7 KB)
explode1.dwg (186.3 KB)
