Sketchup 2027 import dwg and dxf issue
Thanks for new 2027 release and new features in it! Great job! but i d like figure out the issue about import dwg or dxf models exported from 3ds max … non of them is able to imported to SU 2027 anymore in previous 2026 version that was OK … now while attempt to import file it gives such report
… and then import failed … native autocad saved files imported correctly … the issue just in 3ds max exportes files
the result window says that there is no model space data. it likely means that it’s all in paper space, ie. in “layout” mode
can you share the dxf file maybe ?
the same file correctly can be imported to SU 2026 …
Untitled 2.dwg (18.5 KB)
I reported this during beta. In all relevant aspects the importer is greatly improved in the latest version, but for some reason mesh objects do not import. The SketchUp team said they are looking into it.
If you have access to AutoCad, the workaround would be to explode the meshes before trying the import, or to do the same in the 3DStudio export options, if available, or use some other export file format, like Collada.
i d like not refer long bridges for that ops.. i use addons like copy paste from 3ds max to SU …and figure out that it cant import correctly DWG/DXF files exported from 3ds max as before … so i cannot use tools as before …so pity ! lets wait … maybe it will be solved later
I don’t use 3dsmax but I would look what options there are in your export settings. Your current export turns the 3dsmax geometry into meshes. Any other option would work: faces, surfaces, solids…
test for SU 2027.zip (5.3 MB) i attached all compatible formats for SU from 3ds max as chair model sample
There will be a patch soon to correct this issue. I will inform it here when it is out.
The patch with this fix is now released as 2027.0.2 @TYROS4 @Anssi:
