SketchUp 2027.0 is here!
That’s actually a good idea! :grinning_face_with_smiling_eyes: I went ahead and expanded your plugin by adding wood textures and a few other features.
Now all we need is a way to dock it in SketchUp’s Default Tray. @SketchUp developers, any chance of making this possible? :grinning_face_with_smiling_eyes:
You can put the Crayons in the Instructor panel:
Nothing is never impossible…
Here is how the experiment works (and why it can’t be universal):
htmldialog-in-a-sketchup-2027-panel.txt (9,5 Ko)
Thanks for the heads-up! It works, but it’s a bit buggy on my end. Every time I orbit or move around the model, the plugin reloads.
Does the same thing happen on your end?
That’s pretty cool! So docking plugins is possible after all. :grinning_face_with_smiling_eyes:
For this kind of setup, though, I think an ultra-slim plugin interface would work best, so it doesn’t take up too much modeling space.
The instructor panel always show the index.html (in a given path) of the active tool. So it is not buggy, but this is the predictable behaviour.
Every time you orbit or move around the model the Orbit tool is activated, and your active tool is suspended, not reloads, but temporarily becomes inactive.
The Instructor panel follows the active tool. It switches when using the mouse wheel to orbit for me too. But it does not turn off when using it with a SpaceMouse. The Instructor trick and limitations bring us back to your original comment: docking extensions in the panel would be the cat’s meow.
@Hamzah198501 do you mind sharing your version? I’d definitely use it!
Can someone on windows confirm whether it’s possible to install 2027 while maintaining a working 2026 installation. I have production workflows that depend on plugins that may not be compatible yet, but I’d really like to try out the new features.
As long as you don’t uninstall SU2026 it will still work after you’ve installed SU2027.
Model opened in SU2026 a moment ago.
At the same time I have SU2027 running.
@TedVitale_SU in the main trey, please consider implementation of Solo Mode plus shortcuts override (E - entity info, C - components, M - materials etc)
I am still having bug splats on closing every session of Sketchup 2027. It is not retaining Licensing for Extensions. Particularly my Medeek Extensions. This is a huge problem! I have sent in the Bugsplats. I did a restore install with no change. I guess it back to an older version yet again. Its very frustrating! Some Insite from a team member would be appreciated.
yes, they are separate… I have both running
Post the BugSplat numbers here in the forum and ping colin. He may be able to give some insight as to the cause of your frustrations.
The way the team keeps dodging the Shortcuts issue makes me think it’s a well-known problem nobody wants to talk about. Hopefully it’s being taken care of.
Command+A randomly stops working, and I can’t figure out what causes it.
The Eraser tool switches to Unsmooth/Unhide after Command+Z. The tool stays active but changes mode, which makes no sense.
The team members do monitor these threads. I dont write down the bug splat numbers. Isnt that the point of selecting to “send it in” @colin and others have the ability to see any bug splats from a given person. This forum is the preferred support and Tremble takes advantage of generous users that perform the role of Tech Support for free. 2027 seems to have cleaned up a lot of things and there is a noticeable speed improvement. I would like to use it but every version seems to have bug issues, sometime so bad the latest version is unusable. Im not a hobbiest I have work to get out the door. I use Sketchup and Layout 50 plus hours a week.
indeed.
yes and no. when you crash, it get added to the long list of bug reports. when they work on a bug, they see all the bugs from that specific crash.
if on the forum you ping colin or someone else from trimble and give your number (or if your forum email is the same as on the bugsplats), they can go look at a specific report.
that’s why when asking for help (from colin or the tech support), provinding the splat number helps it go faster
Have you turned off / disabled all the extensions to see if SKP works properly?
Some people send in bugsplats without a name or email address, or they may use a different email than the one they use in the forum. Also, the version of SketchUp that crashed may not match what their profiles says they are using. In those cases the bugsplat number would save some time.
You do send in your email address, and so I could reasonably easily find the three bugsplats that you have sent in. The three are for three different reasons. One happened soon after using a Medeek extension, and it looks like most of your Medeek extensions are not the current version. Another crash was related to graphics, and I see you’re using V-ray and Rayscaper. I wonder if those two get on ok? The other crash was to do with closing SketchUp while a sign in was happening.
Hi @marakony We definitely monitor it. Could you provide any exact steps in which the Cmd+A stops working? Is cmd+A assigned to something unique or just a select all action. I’ve not seen this exact issue myself but we have had issues with the shortcuts in the past. Also, not to say the issue is on your end, but just to rule out a keyboard issue, have you tested with a different keyboard by chance?
