Sketchup 2019 Classic License - Log In problems
Good Morning/ Afternoon/ Evening depending on where you are.
I appreciate the time and patience, also already apologise for any grammar mistakes that are certain to be present on this text.
I tried contacting Trimble support team, but was asked to post my problem here, due to the fact that my license is for Sketchup 2019 and Trimble no longer offer technical support for older versions - or at least, as old as mine.
The problem is that the Office I work at bought Classic Licenses, perpetual ones, meaning that we don’t have access to update (not without paying for a new version) and Trimble does not even commercialise Classic Licenses from what I have gathered so far.
So here’s my problem. We have three licenses. One of our PC’s had to log off and now we can’t log back in.
We tried having it reinstalled after a clean uninstall - to no avail. And then tried to install 2019 on a new machine, also with no solution to the problem.
The problem is: after clicking on Add a Classic License, the software does not seem to provide us any field to insert out license detail (authorization code and serial number). So we simply don’t have access to the software anymore.
Both other accounts are still working fine.
Attached is a quick video, following the steps to log in and the “error” we find. Apologies for the bad quality.
Any help would be very much appreciated. Thank you again.
Best regards.,
Marcelo
Could you click on my avatar and send a message to me, with the serial number for the license?
There is currently a problem with versions 2018-2020, where that screen is blank. I can look up whether or not there is a 2021 license available to you.
Hi Colin, I"m having the same credentials screen issue. Can my existing 2019 license still be activated while this blank-screen problem is happening? My previous laptop failed and am hoping to transfer this classic license to my new one. Thank you, JD - Louisville, CO
You too could send a message to me, with your license details, so I can check if there is something I can do to help.
Could you send the information as a message to me, not as a reply in this topic?
Hi, Colin. I am also facing the same problem in the office I work for. I have bought a classic license for Sketchup 2019 and been unable to access the product. Could you please check what can be done? How can I send you a private message? I was unable to find out how.
Thank you!
Good afternoon
I’m having the same problem activating SketchUp Pro 2019—the window won’t load
Hi, i’m having the same problem. Could you help me?
Each of you send me a message with the license details, so I can see if there is a solution to your problem.
Hello! I have the same problem.
Can you help me? What excactly I need send?
If you send a message to me you could include the serial number for the license, your OS user name, and the MAC address of the computer you need SketchUp to work on.
Hi Colin,
Im Having the same issue here, can you help me to activate my license?
You should be able to message me now. Send the information I asked for in my last message.
